leaky oil tank
Sasksummit
My sons 99x is leaking from around one of the brass nuts that are molded into the tank. Anyone know what I can put on or around it to stop it? It is a very little amount but all the same it makes a mess.
yank the whole setup out and run premix. You will save like 10 pounds or more, won't have to worry about that leak, and then there will be room under that hood for a shiny new bottle!
If you dont want to do that goto a body shop and get some FUSOR two part epoxy and use that
Install a rubber washer or two. Can't remember if I used one or two but it fixed mine nine years ago and still holding.
