I've always used a compression tester and had a look at the pistons to determine engine health. Now I'm looking at getting a leak down tester and I've got a few questions.
- What's the proper procedure for doing a leakdown test on a 2 stroke snowmobile engine to determine proper ring sealing?
- I Already know how to pressure test the engine to 5-10 psi to look for leaks like crank seals or throttle body boots.
- How are you holding the clutch to keep the engine from turning over when the piston is at TDC?
- Amazon has $39 leak down test kits, worth buying or go with a brand like an OTC 5609 kit?
- Does anyone have a video of doing the complete test?
- What % leakage past the rings is still except able?
