I have a Polaris axys chassis that I'm building from the ground up, my designated engine will be a m8 arctic cat. This engine has the exhaust and intakes in the same side of the engine. The problem I'm running into is this: by the time I line my clutches up the intake ports end up pretty much behind the steering post. If I throw the throttle bodies on there won't be much room to get my plenum built and attached. My first thought was to machine a block that replaces the reed boots and offsets over to avoid the post. Or install a 90 degree turn down. This machine is fuel injected at the throttle body.
Two questions
1: how much performance will be lost by adding distance to the plenum between the throttle body and the engine?
2: can a throttle body on one of these sleds run in a vertical position or semi vertical
Two questions
