Lawn weeds!
Im wondering if anyone knows any good weed killer that works on creeping charlie.. Its all over my yard and nothing I've tried works :mad:
Same here, patchs the size of cars. Looks like a$$
Tried a few different things, can not kill it.
Some that I have talke to said you can only kill it certain times of the year. There has to be something!
Cut it, dry it, bag it and sell it. Most of the punk kids around anymore won't know the difference.:face-icon-small-win
have chem lawn treat it in early spring. about $75. neighbor had it done and lawn is weed free, and iam appling $30 worth of weed and feed on every 2 weeks and still have crab grass. I know what i will do next spring.
Trimec...hands down the best product you can buy without having to obtain an applicators license.
The best way for a homeowner to apply this product is to use an Ortho Dial-N-Spray and put it on setting 2 or 2.5 and you're all set. You will notice wilting in less than a week and you should have total kill about a week after that.
Good luck, those weeds are tough!
Go to a fram supplier and by a bulk 24d and mix it your self. Be careful not to strong. Add a little dish soap so it will be more tacky to adhear to the leaves. Broad leaf your dead. I did get in trouble the wind will make it drift so be careful. The wifes flowers went down one year.
Weed-n-feed is great...for a couple weeks.
Get some farmer you know to get you a little AMINE. This may sound crazy, but it needs a lot of water to work. Get one of those jugs that connect to a hose (like weed-n-feed). Fill 'er up (quart is good enough), connect to hose and spray. Weeds-b-gone!!!! (grass will be just fine)
Mix up a solution of Borax and water and take a sprayer and apply.
Cheap, and it kills creeping charlie and not the lawn.
Apply in the afternoon sun.....
Mix 2-4d, rodeo, round-up, deisel. a little dish soap ( don't know why it helps but it does) that should pretty much kill anything.
Dish soap keeps it wet longer, allowing the plant to absorb it longer. Diesel helps it stick instead of running off.
A little 2-4D will do wonders.
Roundup and Tordon is a great mix for your gravel driveway. :D:D
