Just wondering if anybody is running an SX kit on their KX450 and what counter shaft and drive sprocket they are using. I have a feeling their maybe a slight difference between the ST and LT kits vs the SX kit. I can get a 13-17 to fit but it's tight and the tensioner is all the way up. When I say tight I mean using a hook to pull the chain tight enough to get it on the sprocket teeth and then using a c-clamp to hold the chain down to get the mater link in it. I am thinking about getting a 16 tooth to run as a drive sprocket so it's not so tight but that will gear me a little higher to.
