KTM Speedometer wires?
C
capulin overdrive
2016 XCW
What are you guys doing with the wiring harness behind the headlight after removing the front end and wire going down?
Disconnect line going down and removed it with brake line. Left the harness behind headlight.
Yep disconnect from the harness behind the headlight and leave it with your brake assembly.
Didn't know if it needed taped up or waterproofed.
Also there is another harness there doing nothing, that it could maybe plug into????
