That’s the most pointless video I’ve seen.
Gearing and top speed?
On the beach?
Does anyone actually pick a snowbike based on that?
Nobody ever said the 4T is more powerful, What is said is the RPM gain and over rev of the modern 4T makes far more track speed then the lower rev 2 T motor, A 2 T will peak around 8500rpm and the 4T 11000 rpm depending on the bore and stroke.That over rev can easily equate to over 8 MPH more track speed with the same gearing . I have both here to compare . A 70 HP 2 T motor with low revving capability's in real world riding has far less track speed than the 4T at 11000 rpm @ 65 HP, HP is great however a real factor is the RPM a motor will spin when it comes to Tracks and snow. Now if you have a CVT clutch then it will upshift keeping the RPM in the HP sweet spot, A gear box is another story and Over rev is very important.
It is so Snowest for someone to call out a reasonable and educated opinion as "dumb" and say "I rest my case" without any counter opinion.I rest my case....[emoji1787][emoji1787][emoji1787][emoji1787][emoji1787]. I find it fascinating that dirt bikers are so dumb. Most Motorsport enthusiasts usually know a bit about what they are riding and the theory behind it. Dirt bikers not so much.[emoji23][emoji23][emoji23][emoji23][emoji23]
I wouldn’t say it is so snowwest. I would say it is a lot more thumper talk. Snow west forums seem to have a lot more educated/helpful/considerate opinions on them. We are a much smaller community that I feel like it’s just trying to help each other out and learn. Some of the comments on this topic make feel like I am on the dirtbike forum. Oh yeah,It is so Snowest for someone to call out a reasonable and educated opinion as "dumb" and say "I rest my case" without any counter opinion.
This was the dumbest video... Almost not worth a comment but a turned up 300 is way better than a stock 500. I'm a big 2 stroke fan but the 500s don't work at all stock. And the vibration makes them a no deal. The track speed is a real deal and I don't mean cutting the lugs off. The more over rev you have past the torque peak the faster ground speed in each gear and gets you that much closer to possibly grabbing the next gear higher when your ground speed catches up to your track speed. Another reason why the 500s are so lame-The torque peak is low and there is nothing after it.
