KTM 300XC TPI Snowbike?
I'm looking into getting the new KTM 300XC TPI for this summer coming. I also have major interest in getting into snow-biking. I'm curious if anybody has done any testing with the new fuel injected 2 stroke KTM has (300XC TPI). It should work just as good as a fuel injected 4 stroke right? I am a big two stroke fan and it would be awesome if the new KTM worked good on a snow-bike. I have searched the internet and I can't find any forums or articles of people using the Fuel Injected version of the KTM 300XC TPI.
Anything helps. Just looking for someone that has some info.
Thanks!
I thought it was only a xcw with pds? Someone has mentioned on here they have one hopefully they reply ..
Sent from my Pixel 2 XL using Tapatalk
Pretty sure they are not importing any TPI 300s into North America for 2018, only 250. But when they do I suspect they will suffer the same way an injected 4 stroke does, that they are not optimized for extreme cold.
I'm curious also! but cant help you with the 19 TPI
I'm currently running a 2017 300 xc-w with the Lectron carb. This thing RIPS!! Last two years I ran a Yamaha 450 and this 300 is lighter and spins the track right now, faster thru the trees,climbs far better!! I think the factory EFI will perform even better...
Ps I'm also running the Slavens S3 head, Scalivinie Pipe,v-force reeds
Twostrokesmoke all the way!!!
Any more research on the 19 TPI would be helpful!!
Is your current setup just a hop on and ride setup, or have you had to do carb tuning to get it the way you like?
I know for me I have lectron on many bikes... It is ride once maybe change the power jet once or twice then ride... They sent a winter rod for my yz.....
I don't run a Lectron or a KTM but do run a 2 stroke. Mine has a PWK carb and I have not had to fiddle with it much after initial set up. I had years of running CR500's with both PJ and PWK carbs and keep pretty good jetting notes and tables. I pretty much just set it up and have only messed a half a turn or so on the screw. Thing rips.
I am seriously thinking about a 300 for my TS120 setup (riding a husky 350 now). My only concern is dumping fuel every tip over. Has this been an issue for anyone? Riding in WA 4000-7000ft
If I were you I would try to get in contact with Kyle Brothersen. He lives in Utah and has a Youtube Channel (Dirt Bike Channel) where he has been testing the KTM 250 XC-W TPI and the Husky TE250i on the single track. Granted it's not the 300 but I am pretty sure he could give you some pretty good insight on how the bike is working on the single track at elevation.
Here is a link to his website and he is really good at getting back to you. https://www.dirtbikechannel.com/
I ordered it from Slavens Racing.....they sent me the Lectron and said....DONT TOUCH A THING....Adjust the idle and that is it!!! If it isn't perfect call us..... I listened and it ran perfect at 1600ft all the way to 11k ft.
As far as I know... for 2018, the only TPI model available in North America is the 250xc-w. Nothing confirmed for more models in 2019 - although it's likely a fair bet.
I have a Lectron on my gasgas. (Summer bike)
(Direct from Lectron)
Same deal installed it without touching anything and instantly had the best running 2 stroke bike I’ve ever been on.
Response is greatly improved along with power under the curve.
300's make a sweet snowbike
Carbs are super easy to tune. Honestly they take like 5 minutes to figure out. Efi, injectors, fuel pumps, add on controllers... more weight, more cost no thanks! I've been down that road and it sucks.
I plan on doing the exact opposite and buying the last year they make the 300 with a carb.
Thanks!
We have a few 300 EXC TPI in my riding group and we all agree that the -18 is a lot better than a fine tuned -17 carbed version. No need for carb heating, more grunt thru the whole register, snappier responce and less fuel consumption.
I ride a good tuned EXC 500 which I really prefer vs the -17 300s or older, but when I change bike I will most likely get a -18 or -19 300 TPI. A few things truly suck with the 300 TPI though and the seat being the biggest flaw. That seat sucks so much it is by far the worst seat I have ever tried.
//Rob
