Kmod 37” install help
Ski-Dont89
I bought sled used and just want to make sure I have upper a arm to spindle hardware in correct order. Aluminum bushing slide in from top through ball joint and then aluminum spacer goes between ball joint and spindle. Is this correct? Also do you use factory washer in between said aluminum spacer and spindle? And also do you use factory washer between lower nut and spindle?
I searched raptor and kmod websites for instructions and couldn’t find an answer. Thanks
Here's a pic of the KMOD 37 on my sled. The spacer goes in the upper a-arm ball joint from the bottom, next is the spacer, then the stock washer. The bolt on the upper a-arm sits directly on the ball joint.
Yes, use the stock washers.
Kevin now has a new spacer for the upper a-arm ball joint that is thicker and no longer requires the separate spacer.
Interesting. I just sourced this hardware straight from Kevin last week and he sent me the old style.
One is not better than the other, just different and fewer parts to deal with.
P.S. I posted that just in case those that get the new bushing upper a-arm bushings don't wonder if they are missing some pieces.
