Just saw this on the KLIM website this morning...
First electric gloves, now electric base layer
Wonder if there is Electric Boots coming??
AGGRESSOR SHIRT EFIRE
The Aggressor eFire shirt adds powered heat elements to the most versatile and comfortable layering system available. Designed specifically for KLIM mid-layers and outerwear, the Aggressor eFire heated base layer traps body heat to ensure consistent warmth for a cold day on the snow. KLIM’s eFire heated technology features two vertical panels on the chest and one vertical panel on the upper back. The heating element includes three heat modes – low, medium and high – with long-lasting heating filaments powered by a USB-C charged battery with a hidden zipper battery pocket.
WARNING: Do not use this product in locations that can be submerged by water.
WARNING: Avoid using this product during an electrical storm. There may be a remote risk of electric shock from lighting.
WARNING: Electronic devices, including heated gloves, eFire base-layers and vests, can cause interference with avalanche transceivers and diminish your ability to conduct a search or be located. To minimize interference, keep a minimum distance between your electronic devices and your avalanche transceiver as follows: in search mode, 20 inches (50cm) and in transmit mode, 8 inches (20cm). Reference the owner’s manual for your avalanche transceiver for additional information
$199.99
Aggressor Shirt eFire
www.klim.com
The Aggressor eFire shirt adds powered heat elements to the most versatile and comfortable layering system available. Designed specifically for KLIM mid-layers and outerwear, the Aggressor eFire heated base layer traps body heat to ensure consistent warmth for a cold day on the snow. KLIM’s eFire heated technology features two vertical panels on the chest and one vertical panel on the upper back. The heating element includes three heat modes – low, medium and high – with long-lasting heating filaments powered by a USB-C charged battery with a hidden zipper battery pocket.Aggressor Shirt eFire
www.klim.com
SHELL/CONSTRUCTION
- Gridded fabric design traps heat
- Flat low-profile seams for excellent minimum-bulk layering
- Engineered specifically for power sports
- Poly-spandex blend
- Anti-microbial
- Moisture-wicking
- Highly breathable
- Fast-drying
- Lighter thinner gussets in underarms reduce bulk and increase breathability/mobility
- Designed specifically for use with KLIM mid-layers and outerwear
- Convertible cuff construction easily used as thumbhole or regular cuff
HEAT SYSTEM
- Heat panels on chest & back (2 upper chest (1 on each side) and 1 vertical on the mid-upper back)
- Lighted touch button control on upper right chest (out of the way of backpacks straps, easy to access)
- Internal wire routing for comfort
- 3 Heat modes: high/medium/low (and off)
- Up to 8 hours on low heat (green light)
- Up to 3.5 hours on medium heat (blue light)
- Up to 2.5 hours on high heat (red light)
- Red-blue-green heat level lighting code
- USB-C battery with LED battery life indicator
- USB-C cable included
- Washer & dryer safe (with battery removed)
- Dedicated battery pocket
- Replacement batteries available
$199.99
