ive got a kitty cat thats got the lift kit in it and that makes a big difference but the track angle is awful. It popped into my head that depending on where shaft in is mounted in the tunnel i cold cut a new hole on each side for the bearings and do drop and gain more track on the ground and a better track angle. only thing i would also probably have to do is cut the running board open so the drive gear has room then put a cover on it on the under side. no reason it wouldnt work but pondering if i want to hack up the little guy.
