Kit
Turbo Kit For Sale
Not sure if its what you're looking for but the price is right.
Pump gas with Water / Air IC means you can run 12lbs of boost on straight pump gas with no detonation, and no reed problems.
$1800 (turbo cost $1200 and has 300 miles on it)
I am an aerospace engineer and I pieced this kit together and made some of the parts. I put a lot of time and effort into it. I owned a dyno and dyno tested this kit and have run it on my machine for the last 3 years. It runs extremely well. I've got a buddy that I ride with that rides a BD kit on a 2011 and he spends a lot of time trying to get his to run like mine.
Last year my oil pump went out and fried my turbo so I bought a new turbo, and a new bulletproof electric oil pump from Cutlers.
I made this kit before the "bolt on" craze hit, but this is a bolt on kit. You don't need to weld your pipe, or drill any holes other than a boost reference on your throttle bodies and a fuel return back to your fuel tank.
Garrett 2860RS Pump Gasturbo kit for M8 with Water to Air Intercooler
Attitude Industries fuel control (twisted programming)
MSD External Fuel Pressure Regulator
Garrett 2860RS ball bearing turbo
Cutlers Performance Electric oil pump
Frozenboost water to air intercooler with separate heat exchanger in tunnel and Bosch water pump.
Boost gage
Innovate wideband 02 sensor gage
Twisted Clutching (Helix, Primary Spring, Primary weights)
Bosch Blow Off Valve
Custom Port Tuned Airbox using O-ring joints
I have this kit installed on my M8 right now, it runs awesome, but i've got a new sled and the turbo is coming off this one and becoming a wives sled.
Let me know if you're interested.
I'm in Northern Utah.
-Jeff
