King Cat Primay clutch set and torque specs??
clutch torque
i always torque to 55 foot lbs then ride sled for 5 minutes or so and then retorque to 45 foot lbs.I also recomend taken clutch off ever year and clean crank end and reinstall clutch if you dont the clutch works on to the crank and ten the bolts is a little loose then it will loosen up more and the clutch can get loose from crank and break bolt then clutch comes flying off i had this happen several times before i figured out what was going on. Dont just retighten bolt every season because if you do when you need to remove clutch it is really stuck on there
