i am parting out my 2004 king cat 900. it has 1024 miles on teh motor. its the carb model. it has snow eliminator running boards, polaris hvyo 20/46 chain and gears, d&d power pipe and can, v force 3 reeds, wahl brother 8 tooth extroverts with about 250 miles on them, 2 brand new belts, fox shocks with reservoirs on teh front. this is somewhere on teh lines of what i would like. let me know what you want and we can work some thign out you can call or text 208-430-2431 or email justinomaughan@hotmail.com i check email several times a day
motor 1200
rear skid
fox front shocks 250
belly pan left 50
belly pan right 50
belt guard 25
brake assembly 75
carbs 250
cdi harness 100
cdi unit 250
chain case 250
chain case guard 15
drive shaft with sprockets 150
engine mount 25
exhaust valve condensor 90
exhaust valve regulator 100
front rear shock 125
handlebars 75
heat exchanger left 50
heat exchanger rear 100
heat exchanger right 50
hood 375
ignition coil 60
lower right a arm 50
lower left a arm
luggage rack 30
pipe & can 250
primary clutch 150
rear bumper 30
rear rear shock 125
reeds 50
seat 150
secondary clutch 150
servomotor 150
skid plate 50
skis 100
speedometer 50
spindles-left 50
spindles-right 50
steering post 25
stock front shocks 150
tachometer 50
tailight 15
tarp 80
tie rods 20
tunnel 200
upper left a arm 50
upper right a arm 50
wiring harness 50
Snow eliminator running boards 75
Gas Tank 50
motor 1200
rear skid
belly pan left 50
belly pan right 50
belt guard 25
brake assembly 75
carbs 250
cdi harness 100
cdi unit 250
chain case 250
chain case guard 15
engine mount 25
handlebars 75
hood 375
ignition coil 60
lower left a arm
luggage rack 30
pipe & can 250
primary clutch 150
rear bumper 30
rear rear shock 125
reeds 50
seat 150
servomotor 150
skid plate 50
skis 100
speedometer 50
spindles-left 50
spindles-right 50
steering post 25
tachometer 50
tailight 15
tarp 80
tie rods 20
tunnel 200
upper left a arm 50
wiring harness 50
Gas Tank 50
