king cat compression
Depends on your elevation, @ 3300 ft I usually see 135-140 on a stock head that hasn't been cut. The higher your elevation the lower your comp.
Seems a little low. Any porting done? Porting and deck height will change it quite a bit. If not, it is getting close to the time to freshen it up! Check it with a different guage before you get too carried away, I've seen some off 15 to 20 lbs.
