right now i am in the process of tuning my m7/8bb clutching to reach the 8100rpm mark, up from 7800.
i have a basic understanding of how my sled's clutch components work, but my experience with clutch work and maintenance (up till 2 days ago) has been limited to installing an rkt torsional mod, and changing my belt.
so i need to gain 300rpm. i'm told that i should increase primary spring pressure, and decrease primary weights. i started with changing the spring in the primary. i went with the orange/black which the shop guy tells me is the same spring rate as the black/orange in the new sleds, but it doesn't snap. the original yellow/white looks pretty sacked out. (like i said, i never did much clutch maintenance in the past)
on the mountain i was getting engagement at around 4000rpm, which was definitely up, and it felt like much smoother acceleration. on a nice long hillclimb at wide open throttle i was seeing that 7800rpm, but then after about 200 yrds (and slightly steeper pitch) i saw the rpm creep up to 8000 rpm, and hold there for the rest of the climb (about another 200 yrds).
so now i'm wondering, why did it take so long to hit 8000rpm? is this typical?,
do i need to change more parts?,
could this be a result of some other worn out part that i should be looking for? (ie. primary/secondary rollers).
can belt tension play in as a factor? mine was a little on the tight side, but i didn't have an allen key with me to loosen the bolt and play with the tenison.
i also read up on my rkt torsional, and apparently by adding more preload spring pressure, the motor should wind up quicker and give me a little rpm at the top. is this the answer?
and if anyone would like to elaborate, i would love to hear about any common problems that do occur, and what symptoms to watch for to identify them.
sorry about the long post!
