Khaos to pro conversion
P
provoyager
12
5
3
Alaska
I have a 22 khaos 155" and am looking to convert it to a 165" pro. I found a pair of take off pro 165" rails, but do I need to do anything special, or will this even work? Will pro rails and a 165" track be enough or do I need to change the front arm and track shock? Thanks for the help.
ryang85
41
61
18
Oregon/Norcal
Suck in your limiter strap and you'll be wheelie a bit less. Going from a 155 khoas to a 163 pro is going to completly change the feel of the sled but if you want to go that way your better off going with the khoas rails incase you ever want to go back to having more playfulness. Running pro rails on a khaos front shock and limiter strap has potential for stabbing but if you adjust the limmiter strap to the stock pro length you should be fine with pro rails.
P
provoyager
12
5
3
Alaska
Do
Will the skid mount in the same hole it is in currently or move it to the other mounting hole?
goridedoo
3,868
3,546
Same hole. A Pro is rails, front track shock, and limiter strap. I converted my 165 Pro to a Khaos. I have shocks, red rails, and limiter strap laying in my shop if you are interested in any of them.
ryang85
41
61
18
Oregon/Norcal
Will you trade for spark plugs? Asking for a friend.
A few 100 pack cases should last the rest of the season. That's the new currency for us polaris owners in the parking lots.
But same hole. The only thing that will make a difference is the limmiter strap.
ullose272
3,372
963
boise idaho
Have you ridden a 165 pro? I couldn't stand a 165 khaos. Was way to planted for me
Sent from my SM-S911U using Tapatalk
JH@CM
498
777
93
Khaos 155 to Pro 165 is quite the change. Why not put on the longer rails, track and test for a few rides without changing the shocks/strap and see how you like it before changing anything more?
D
Mar 8, 2014
1
-1
1
Hey, goride do, I may be interested in your Pro suspension parts. What would be the best way to connect?
