Khaos Conversion Kit Question
Your anti-stab kit should go in line with the limiter strap shaft. your rail tips need to be cut off. It looks in your pictures like you just took the rail caps off and put the wheels there? If that’s the case that’s your problem right there
Hahah! Look up raptor rail tip Anti stab kit. You drill the hole out from where your plastic caps are on your rails then install the wheels and spacers right through the same hole. I'm glad I didn't cut my rail or id want new rails.
Sent from my CLT-L04 using Tapatalk
