A
I was wondering if anyone knew if the trs alignment bar from the axys works with the p-22 clutches. The run the same belt. If it does work for the boost do you use the same measurements? Mine is quite a bit off if this is the correct alingment bar. I have about a 3.68 mm gap.
Sent from my SM-G991U1 using Tapatalk
![d862126b6db29a0241485e029ff6ce62.jpg](http://uploads.tapatalk-cdn.com/20220117/d862126b6db29a0241485e029ff6ce62.jpg)
![32f3a363a5847a019946d2113b0db630.jpg](http://uploads.tapatalk-cdn.com/20220117/32f3a363a5847a019946d2113b0db630.jpg)
![8e564c21ca11f9ca0301bb8f5644a03c.jpg](http://uploads.tapatalk-cdn.com/20220117/8e564c21ca11f9ca0301bb8f5644a03c.jpg)
