Keep having stator problems
M
minecat
I have a 2007 M1000 that I built my own turbo kit for and I have went through 3 stators within 600 miles I am running the BDX pump AEM air fule gauge and no headlights or tail light I thought that when I was running the head lights that it was to much for the system seeing as how my stator problems started when I put the headlights and AEM on, I also had koso EGts on as well but took them off when I unplugged the lights when the last stator went out. The sled ran great for the last 300 miles and now the stator has gone out agian. Does anybody have any ideaa what could be causing this very frustrated.
Thanks
Stators
Are you buying OEM ? I have a couple in stock. I have a used one out of a short block with about a 1000 miles on it for 300.
I am using OEM stator get them from cat speciality products I have started to check all of the wiring and nothing is evident so far, also have tried a different CCU still went bad I am going to be tearing this thing down in the next couple of days so hopefully I will find a bad wire until then I am stumped
