Hey everyone, ive been chasing a rpm issue with my 2011 800 for quite some time now and finally figured it out and just wanna up date everyone has tried helping me out. The symptoms i was having was a wot throttle bog, couldnt get to rev out over 8000 rpm. Everything checked out good/had been replaced. Only thing that was left that i didnt do was the pistons. The sled ran great and had no problems with wot rpm and pulled 8300 with 68g weights at 2000elev untill i hit the 400 mile mark. Now have 900 on it. Today i installed new wossner pistons and wow! Woke sled right up! 8250 rpm with 71g mtx with 3 gram in tip and 1 g in heel. Finally!!!! The old pistons were so out of round it was shoking. Cylinder measured 3.345. Stock pistons were 3.337 ! The ring lands were sloppy as well with .013 play in rings! These pistons only had 900 miles on them and Compression was still somehow 128psi. Oil pump was turned up and is 55-1 ratio. New wossners were 3.341. Little on the tight side! I set the ring gao at .020. After a short break in ride the comp is 130 warm. Anyways im happy!!! Hopefully this post will help some other people.
