how are you removing the bolts that hold in the weights. I tried to change mine and after removing the set screws I couldn't get the bolts that hold the weights , it seemed as if they were pressed in and I didnt want to beat any harder with a hammer. are these usually hard to remove
- heat up the set screw with a small propane torch, 10 secs of heat should be enough to weaken the thread locker
- remove set screw
- take a punch and tap out the center bolt, notice each side has a super tight bushing, super tight is good on this application
- i like to trace the weight with a tap if said weight is used again
- take a pic and get remove the thread locker that is in the center bolt set screw hole
- put stuff back together
- line up the set screw hole with the center bolt hole nice and good
- heat up the hole for 5 secs
- heat up set screw 5 secs
- add some thread locker to both the set screw hole and set screw
- install and tighten while its still a bit hot
- wipe up thread locker funk
be happy
