just put jaws twin pipes on my skidoo xp 860
the jaws pipes seem to work good so far, have not had it out for more then 10 min but it pulls hard so i think they will work good and they sound good to
I believe terra alps has the jaws twin pipes out for the 860 already. The jaws twin pipes for the 800 are not out yet as far as I know.
well i'm slapping on a set of crankshops with an SLP head tonight.. also rejetting and running some C111 and throwing some thundershifts on with a bunch of weight ... but I'm not porting the cyls, so I hope that combo brings me some good hp numbers..
you think porting is really gonna make that much of a difference? i'm guessing 2-3 hp at most.
i find it very hard to believe that jaws is going to make a set of twins for the XP that require porting to get any real power increases from. The stock Doo pipe is SO good that twins won't help!? Ya right. An individual pipe per cylinder can always be built to make more power than a single - FACT.
I'm not saying i like messing around with twins but come on...
Not on a doo. Bombi has done their homework on their exhausts.
Many have claimed 12 hp on just a set of pipes, That I think has yet to be seen.
Jaws was claiming 19 hp last year-but we have yet to see the product. The Twins that Terra Alps has for the 860 are NOT Jaws. He made that clear in another thread. Maybe somebody can make a set of twins that work for the Rotax with out removing your hood;)
You could look at it the other way also. Poo and Cat need to step up and make a stock pipe to the engines full potential..they must be in bed with the aftermarket companies:)
What happened to "The King" was that his first and last post? Hi, I'm new I just put a pair of jaws pipes on my big bore and they worked very well for 10 minutes, goodbye it was nice meeting you.
dialing
probably in the process of a full test and tune. i know i wouldnt be all talk on here till i had the sled fully dialed, and we know how long that takes.
