Just oicked up a 2007 M1000 tonight, 1500miles, great shape.. what should i watch out for, anything to know about these sleds? This is my first Cat
I want to say 8 lbs on the boss seat.
Some other things to look at:
-Bd-xtreme black box intake saves about 8lbs
-Bd-xtreme 2 wheel kit 2lbs for $20.
-Bd-xtreme chromoly suspension parts.
-porting track 2-4 pounds
-arctic cat sells a bushing kit for the arms that saves like a pound.
-fox float conversion for the rear suspension from cat saves like 8 pounds.
get 09 clutch springs installed and a powerClaw, make sure clutching is aligned and deflection is set right. the power claw will get you farther than anything right now.
Thanks Marcs--
I cut the very top off my intake about an inch or so down and
install a cone shaped air intake which now sits right under my hood up nice and high...This way theres no well or place for the snow to accumulate. With filters i also found that bigger isnt always better....K&N's all seem to let the air in no matter what the size.
I would not recommend the Bd-xtreme intake box....I had it on my sled and it was really boggy in any kind of powder. So I put the stock intake back on and it seems to work a lot better, and didnt see much of a power drop when I switched back to stock. just my .02.
We have had the exact opposite results with the BD-X intake. Works great in deep powder have sold about 100 of them. Use on my personal sleds ride deep deep snow they work great. I have heard in extreme cold 40 below the snow can get fine enough to get through but in my area they rock.
bdx intake and oil delete made my sled pull harder than I thought it would, the stock intake is engineered correctly to meet fed. laws. its mainely to cut down on noise and still provide air.
running slp pipe set bdx intake oil delete bd box some clutching
I have the bd box set pretty close to slp rec #'s but in the middle did not take away any fuel and bumped up my fuel pressure 3lbs to 48lbs when I installed the bdx. egts read where I want them.
the 09 secondary spring is different, been told its the same but it is a lot stiffer i am sure of that. but my 09 stock with the 60 belt flat ripped for a stocker. not sure about the primary.
