Im gonna start w/just a 30 shot and would like to hear from those that have been running NOS for a wile. Post some tips on safe usage and Good bad and ugly stories![]()
Just don't use it on one of the really weak motors like a Polaris 700 or something like that.
It going on a 05 rmk 800 w/pipe,can,reeds,intake and clutching mods.
Hey Phil, I'm just messing with you since I knew what you were putting it on.
Robert Lindsey
Unless you have a pressure regulator I've found bottle pressure (temperature) to be critical.
i run a regulator...also have a guage.
a cold bottle in the morning produces about 300-600 psi depending on temp..
once warmed it jumps up to about 900-1000psi
you can tell on the higher hp shots
if you keep it low say 10-20hp the pressure doesnt make to much differance with the regulator.
adjustable regulator is the way to go tho no doubt.
i run mine close to my can to get it nice and warm..a bottle warmer might still
be a good idea because the aluminum bottle soaks up so much cold temperature even when its under the hood when you touch it its still very cold.
anyone know how warm is to warm? in psi? my guage goes into the redzone at about 1200psi?
I also run 5 gallons of 110, I am thinking about scaling back to about 2-3 gallons per tank, but it runs so stinking good with the full five that i cant talk myself into reducing it!!!!. I was told that i would need to run 1-2 gallons to keep the knock sensor on my XP happy, so i started out with 5 gallons planning to work it down but i just cant do it. I wish i could afford to run straight race gas...............the differance is freakin amazing!
