So I just replaced my jack shaft to the 15 style. Bought the update kit, it came with the hub and pto bearing installed and also came with the chain case side bearing, snap rings etc. so install was easy but the top gear now has a snap ring to hold on the gear instead of the bolt and spring washer. So does cat want this top gear to float on the shaft ? Does not seem right!
No spacer or shims to take up the gap behind the gear. The only way for the top gear to be parallel with the bottom is if the top gear is flush with the end of the J shaft.
It looks to me I need to tap the J shaft and find something to shim/space the top gear, it's all of a 1/4" maybe 3/8 away from the snap ring the holds the bearing. I did not measure as I was a bit pi$$ed and walked away
