If you buy a knew one look at a Craftsman. They have good customer service >>>>.
To be honest that was the very first one I looked at.
But the reviews of the new ones are HIGHLY mixed.
By and by it looks like the quality we grew up with back in the day is a thing of the past!
DON"T WASTE YOUR MONEY April 01, 2009
Had to tighten all the air fittings on it first to get it to hold psi. Found the drain to be so special...ya gotta love that one.....wonder what chinese design engineer brain farted that one.
This one doesn't have the scfm as stated...but what the heck, I've had 3 Craftsman air compressors now and found that MOST CRAFTSMAN AIR COMPRESSORS DO NOT PUT OUT THE SCFM THEY CLAIM. and yes i used this one and the others for several different tools that have very defined scfm ratings so i'm not guessing when i make that statement. so if that is an item of interest to you BEWARE.
At the 62 day mark of NOT MUCH USE it started to make a noise. didn't sound metalic but thats water under the bridge now because at that point the motor decided to spin without compressing anything and was kind enough to to spread a foul odoir (lol) around my shop.
I moved away from Craftsman power tools a while back and will move away from their compressors when i need another one. QUALITY might have been good once but it has been my hands on experience ( 30yr engineer ) that it has dropped off.
26 gallons of ***** July 07, 2010
By
treetrashish of Warren, OH
See all of this author's reviews
Cons:
drain is a joke on many levels, cheap chinese junk
never had enough power then after 3 months past warranty the pressure relief tube blew. the new tube was inexpensive but the elbow where it goes into the regulator is unavailable( when you remove the tube it ruins this) although they will send you the wrong part as many times as you call them... this machine would be good for anyone wanting to blow air at their face after a long hot day.. otherwise don't waste your money. It does however make a good shiny red garage ornament. I'm done messing with this piece of **** and am going tomorrow to buy a real air compressor. trust me, adding oil once in a while is far better than dealing with this P.O.S. oh by the way as someone else said be prpared to change the drain valve as it leaks air from the very start.
good but you will have to pay extra to make the drain workableOctober 12, 2009
By
diymikef135 of San Diego, CA
Pros:
low maint (no oil changes), easy to move around
Cons:
loud, drain is a joke on many levels
I bought this compressor to replace an older craftsman 3.5HP, 125PSI, 25 gallon that developed a pinhole leak due to lack of draining on my part (draining is a pain). Overall I can't say this is any quieter than the old model. The drain design sucks and I knew this going in after reading the reviews here. My solution was to use the slightly larger wheels from the old compressor (I just scrapped the tank) which gets the drain off the floor a bit. Then I added the "enhanced" drain system at the link below with some parts at **********.
http://www.hammerzone.com/archives/workshop/compressor/drain/ball_valve.htm
The one thing that ****** me off was the initial break in. I thought I had the drain valve open (I turned it as far as I could with my fingers) and turned it on but then realized the drain was NOT open!!! I didn't run it that long so not much pressure built up but still irritating. I then got some pliers and opened it all the way and of course rust shot up in my face. When I pulled the drain to replace with the ball valve I noticed it looked all mangled so on top of everything else the drain valve itself was defective which is why it was so difficult to use. So for the initial break in I recommend just removing that valve up front.
So the modded unit is pretty nice now ... the handle placement is great for a 6ft guy like myself so moving it around is not too bad. It came with 50ft of hose and a note saying they replaced the 25ft specified length so that was a plus.
