D
DM116
Is there a way to have Polaris reflash a ecu to take the safeties (DET, pipe sensor, rpm, temp, etc,etc...) out of a stock ECU? The reason I am asking this is, I am planning on building a watercross sled and I do not want a sensor failure sending me into safe mode on the water. I am coming from a ski-doos where you sent the ecu to the race department and they would remove a limiting sensors and safeties that would allow sled to go into safe mode.
From researching I havent found that you cant do this on the polaris at least according to the race department but they also said they have limited knowledge in the 800 CFI-2 motor as they of course run the 600 carb in sno-x, ice oval and cross country.
I know I can change with the Vi-Pec but dont really want to spend 2 grand just to remove safeties as I am running in the stock class with stock pipes and heads and I wont require a new fuel map
