I agree that a shorter limiter strap decreases the approach angle. But I have found that it also tends to submerge my ski more and make it hard to loft over things. So do you sink your ski or your track?
This will also work on the ST and LT's.I have an SX kit and what I have done is gone up one hole on the limiter strap. This lengthens the approach angle and wont trench as much. I also have added a 1/2" shim on the bottom of the rear suspension slides. This helps couple the suspension. I made this out of some PVC pipe so I can remove them when I need to race or trail ride for some reason. I also added a 1/4" shim to the top of the slides so the ride height is slightly lowered. An individual suggested this to me on Snowest and I think it made a big difference.
Shortening the shock rod makes sense to me and it would also drop the seat height, right?
That's not a bad thing in my book.
Shortening the shock rod gives you more ski lift --- that is why you can suck up the limiter strap if you shorten the shock rod.
On the Ktm 530 we did cut of 1/8 inch on each end of the shock rod to allow for some extra adjustment. That will allow you to suck in the limiter strap by at least one hole while still having more ski lift than before.
We have done this for the last 2 years now Timbersled is doing similar setups.
cheers……..
I have an adjustable shock rod, I wonder what the stock length is for a CRF450? and I take it, you have an adjustable one with the ends cut off with eyelets screwed in more correct? and what strap hole are you using? Thanks for the info
