Is the performance of my ‘24 boost being affected by altitude because of clutching?
My ‘24 patriot boost has been the most underwhelming sled I’ve had, 800 miles of issues and poor performance. I’m pretty new to the aftermarket game, clutch tuning etc but this issue is starting to feel like a clutching issue. Before I go spend money on a kit I’d like to hear troubleshooting suggestions in case the problem is elsewhere or if these things are really that bad stock.
The issue: the sled seems to be pretty heavily affected by altitude in regards to max rpm’s and power. The higher the elevation the lower the max rpm’s and overall performance. I know that’s usually the case, but I figured a turbo sled would do a bit better with elevation changes. My elevation range is 7200 ft to 10500 ft
What I’ve done so far: for aftermarket parts I have a gen 2 silber can and mtntk under hood intake. I’ve taken it to the dealer and they replaced the injectors and injector harness as well as a watergate actuator relearn. The sled felt a little snappier after that work but is still not where I think it should be.
When I got it back from the shop I test rode it and at 7200-8000 ft I only had a max rpm’s of 7700 and could only build boost halfway on the boost gauge. I then switched from the stock primary spring (165/310) to a mtntk spring (150/320). At 7200 ft I could then easily pull 8400 rpm’s and had 3/4 boost on the gauge, riding up to 8k ft the max rpm’s only dropped a little. Then I took the sled up to a starting altitude of 8300ft and went up to about 10300 ft. At 8300 ft I couldn’t get past 8200 rpm wide open throttle on the trail, and that dropped to 7700 rpm at 10300, and the boost gauge didn’t show much more than half except when I let off the throttle.
When I bought the sled it had the high elevation clutching which, the Polaris website says is for 5k-13k ft.
The question is are other people seeing the same thing on their stock clutching set ups with the optimal altitude being lower than 8k ft? Or do I have different possible issues I need to look into?
Thanks for any insight
Clutching is OK from the factory. It shouldn’t be that unless something is broke or wore out.
Have you tried a different can?
Stock clutching is often a bit light (high RPM) around here 5,500-7K' ish. So it should be "good enough" at 7-8K+ if all clutch components are in good repair.
Have you compared with stock can and/or intake? That would be a worthwhile test.
Update:
I took off the silber can and put the stock exhaust. From 7200 ft to 10k ft I was able to hit 8400 rpm’s. I did start to notice the higher in altitude I went the more sticky the top end was. At between 7600 and 7900 the sled would sort of plateau then if I held the throttle wide for long enough it would break through and rev higher. I checked the primary spring and saw some wear(pictured). When I got home I measured the spring diameter, the MTNTK springs are a bit wider than the stock spring. I’m thinking this could be the stickiness on the top end of the rpm’s. I made sure the clutch cover was seated properly and wasn’t on cockeyed to cause the rubbing. Unfortunately the shop didn’t have new springs so I won’t be able to compare what the new stock spring until next week.
Also, primary springs are to be replaced every ~500mi or sooner, especially with the P-22.
Did you end up going back to a stock can or another aftermarket can? If aftermarket which one are you running that works?
update: still have had some under revving and boggy conditions inconsistently. I pulled the exhaust valves just to see what they were looking like and they might be another piece to the puzzle. They were filthy. Oily gunk all over them and they were very sticky trying to get them to move. This is at the 820 mile mark.
I’m wondering if the silber exhaust had too much back pressure from the baffle and might have been keeping exhaust in the system longer than normal to cause this? Or is this something that needs to be kept up with more often than 800 miles?
3-500 miles usually
i would start with checking the clutch alignment and run a new polaris belt. i would also scotch brite the hell of the clutches. i have a 23 850 165 so I'm not familiar with the boost sleds but if the secondary calls for "float" i would make sure it is set up with it. I suspect chasing aftermarket clutch adjustments is an unnecessary detour.
