rmkboxer Well-known member Lifetime Membership Jan 28, 2016 #1 I need to verify the axys drive shaft is the same as a pro other then the drivers. same length and the ends are the same for the bearing and the belt drive.
S Sheetmetalfab Well-known member Lifetime Membership Jan 28, 2016 #3 Its been talked about numerous times this last fall..... As long as you are talking swapping belt drive to belt drive, or chaincase to chaincase they are the same. (Shaft that is) Standard buzzfeedhorse cautions apply. Belt shaft wont fit chaincase Etcetera
ullose272 Well-known member Premium Member Jan 28, 2016 #4 I put a axys shaft in my pro. Axys uses a different lower bolt (longer) and axys uses bolts on the pto side bearing retainer instead of nuts Sent from my SM-G900V using Tapatalk
