is the 2013 and 2014 engine interchangeable ?
rab
can I bolt a 2014 eng into a 2013 chassis ?
I see the crank cases have different part #s
the pistons have different #'s as well !!
the cylinders have same part # !!
They interchange.
Supplier change = part no. Change.
  • Like
Reactions: rab
The only difference I know of;
Is the '14 TPS has a pigtail (to alleviate some of the condensation / water intrusion issues) and a different connector (Triangular). Where as the '13 has the connector built into the TPS and is a flat (Rectangular) 3 pin. Other than that and the yearly updated fuel mapping in the ECU it should be a plug and play. Swap the '14's TPS to the '13 style and go.
  • Like
Reactions: rab
We talking just a short block change? Or electronics etc change? Shortblock is the same and will go right in and hookup with no issues. In 14 they upgraded the pistons, but I would get rid of Poo pistons period in there 13, or 14+'s.
  • Like
Reactions: rab
