IQrr clutching problem Please HELP
I have A 2008 IQrr 600 with a slp pipe and can. A 136x2in track it is has a team tss 98 secondary with a 60-42-36 Helix a 160-240 secondary spring and a Delrin washer kit the drive clutch has 10-62 weights and the factory white with a red stripe spring. I also geared it down to a 1.95 ratio. At wide open throttle or in any soft snow off the trail by belt and both clutches become very hot and I am having frequent belt failure. I check my belt deflection often and the alignment is correct. I ride at 1800 ft and the motor is revving 8100 rpms. Please any suggestions
