iq over heating
Hello first time have have problem with my sled over heating its an 07 iq took thermostat out but no luck haven't taken it apart yet just wondering if any one else has had this problem before I go to water pump
What sled.. short /long Track,,
Not a big issues normally.. Any coolant Leaks??
What is the temp that you are seeing? 125-130 is Normal
No leaks long track run for 1 - 2 hours ran just fine stoped to eat start going again light comes on temp at 150 stop unscrew bleeder in gooseneck air comes out then foam in coolent bottle temp never came back down was snow on trail can only think its propeller in water pump checked compression 135 in both
Well 150 is normal to see right after you start up after a short break. if u watch the gauge it will cool right off.
Sounds like you just had some extra air in the system.
Just watch ur temps.. ur fine..
