^^^^ This is pretty much what I am looking for.. Needing it a little customized though..
I am actually going to be running the IQ gauge setup on a pro because of the motor that I will be running, so basically what I need is the Pro gauge lifter that can use the IQ gauge instead of the Pro gauge. The Timbersled setup would work for this, but I dont really like the bulkiness it adds to the bars..
MountainFit, would it be possible for the lower portion of the Pro lifter to attach to the upper part of the IQ lifter?
So YZ, curious what you are doing? Reason I ask is I would like to move to a Pro chassis at some point a year or two down the road, but would want to take my 08 Carl's 860 with me... picked the sled up late last season for a good price, and it would be awful expensive to build that motor over again based on the Pro motor...
what's the benefit of any of this?
what are you looking for that often?
I may keep you on my list, if I run across a PRO chassis I may ask you how this project went, what all you had to do to adapt the CFI700 into that chassis etc. - the Carls 860 has the same electronics, fuel system, etc. so hooking it up should be identical...What I am probably going to do is use a CFI 700 motor in a pro chassis and the pro gauge will not work with the wiring and electrical from the 700.
<snip>
Unless you get bored and want to send me the how-to now. Complete with parts list etc.
Cool. I will go check it out. If I find a deal on a rolling chassis that will be the direction I will probably go, although I am happy for now with the Dragon chassis (have not ridden a PRO yet).I have this project posted in the build section of this forum if you want to follow the progress. It's slow going right now, but should get going again shortly..
Sent from my Galaxy S 3 using tapatalk 2
