Intercooler fan
Nytroboost
Looking at installing a intercooler fan anyone know of a good place to take the power from and if its worth putting in. Thanks
Pull power directly from battery and use a relay from a switched 12v source. I would imagine that a fan would help more than one would think.
If you have removed the radiator then you can use the fan from the rad and the relay that already is installed. All you have to do is cut the ground wire of the relay since the ECM sends a ground to turn on the fan then take the wire and ground it and the fan will run when the ignition is on or figure out a way to put it on a switch it will already be fused and every thing works pretty good.
Yes rad is removed alpine front mout kit haven trouble locating the plug for the rad fan do you know where the plug might be located and which relay it uses. Thanks
I have cr tunnel so the fan that was on the stock rad is the fan I used. Like earlier in the thread it's set up for it real easy install now just waiting for snow to see if it makes much differance
