interchanging BigWheel Kit REV
The new chassi or skid is set for a 16 wide track on the XP instead of 15 on the older Rev. Wondering if you could mod an axle and bogie stock from a 09 and put it on a 05 Rev?
Xp axles are smaller Diameter than a Rev so no. Summit rev run a 16 in track mxz run a 15 in wide, A 16 wide will fit in a Mxz you dont have to change the axle. But you do have to remove some braces and some rivet need to be grinded on the tunnel a bit for a 16 wide to fit. Consumer models require less work than a racer model {MXZX 440} Because they have more bracing.
