Insulated trailer floors, is it a good thing to do on a new trailer?
Keeping the ice OFF of my trailer floor was a challenge this winter.
Even with the heater running, that was THE COLDEST part of the trailer all winter and would always freeze up at night just as soon as the heater was turned off.
Ya, I'm thinking the insulated floor would be nice. it'll cost about 2 K extra on a 22' footer.
It would sure be interesting to have.
Question is, WILL it work ?
The problem is getting the heat DOWN to the floor level to begin with.
Insulation stops the heat from getting out, but you have to have heat down there in the first place to stop from leaking..
How the heck do we WARM the floor when heat wants to rise to the roof level?
I've never seen a factory insulated floor. I insulated my old trailer floor but, I would be concerned about trapping moisture in a trailer that I was planning on keeping forever.
We did it to mine when it was brand new, threw it on a lift and sprayed the bottom. Seems to work well, and I like the protection it provides to the underside.
I don't know if insulation completely seals the floor but if that's the case it'll sure hold a lot of moisture in that would normally drip out.
Can't speak for any other trailer, but it sure seemed like mine drained everything out of the tail.
The real challenge was HUMIDITY in the trailer.
Just couldn't keep it WARM and DRY at the same time.
am i the only person that has been dreaming up a way to do radiant heat in the trailer??
works way to good in the shop, lay in some pipe, spray over it, maybe quick couplers to the truck to drive coolant for heating?
ok, back to reality. less dreaming!
install a heating pad like they do under ceramic floors. then cover it with tile or spray liner, or flooring of some kind. your not trying to heat the whole trailer with it because, you already have a heating system. you are just trying to keep the floor warm to allow the water to drain. make sure there are drains, and angle the trailer so it can drain while drying the sleds. you need a good vent and a fan system to avoid the humidity in the trailer too.
Ski
