Installing Fox Zero Pros on 06 700
C
C-dale rider
New member
I got my zero pros from carls cycle, but they did not come with installation instructions and I think I may have put the shocks on wrong. Do the zero pros go right side up (with the logo the right way), or do they go upside down (so the logos are upside down)??????
I tell you if you were to purchase Zbroz Exit shocks you would not be sending out help when it comes to installation. I have an 2006 Poo RMK 755 with the Zbroz front and rear shocks and i will never go back to Fox (subpar shocks) shocks again.
You may have to grind the upper mounting bracket a little. Mine was rubbing on the shock. The piston must go down though, unless you were to grind the upper mounting bracket alot to make room for the spring holder. The shock works the same in either position though. What weight of springs are you going to run?
Also, be sure not to over tighten, it will crush the bushings.
8 ft/lbs is all it needs.
So tell me how your post helps C-dale rider how??? Purchasing different shocks helps with installation? Just because a guy spends a fraction of the money on a quality shock compared to what you have, they are sub-par? Help a guy out, don't kick him down.
