Installing EBC question
I have a 2009 rmk 800, it has the boondocker kit and i just installed the EBC unit, I was just wondering how to hook up the TPS plug (at least thats what i think it is) Its the white stand alone wire off the harnest...
I have everything else hooked up and calibrated... can i run it without the TPS hooked up?
There is a seperate harness that pig tails the TPS and factory injectors. The standalone wire goes to the Bd control box if memory serves me well. Ill check tonight and get back to you, it may be going to the TPS harness, just cant recal off the top of my head.
Ok thanks... Here is a pic of it if that helps...
Yup, found it, it plugs into a pink wire coming from the tranducer harness. The same harness piggy backs the TPS and interties with the BD control box. It has 7 connectors in total. The other connectors in the harness go to the temp sensor EBC transducer and the push to pass button on the bars. This is on a intercooled kit so you may have some different positions if its not intercooled. Hope that helps.
PS, its not the TPS connector its the EBC harness. The TPS connector is on the t-bodies on the PTO side of the sled. You will need to jumper those out with the BD harness kit. They left mine out when the kit arrived and i had to call and get it sent out. I actually had two kits and they missed them in both kits so you may be missing it. If so just call them and theyll be good about getting it to you. There are so many pieces in those kits it didnt suprise me that they missed somthing.
Got it figured out boondocker left a plug off the harness. So that's why i couldn't find where to plug it in at. Boondocker is shipping out the connector so i can fix it. Boondocker customer service was awesome both times i called!!!!
Thanks...
