And one with my big fat thumb depressing the valve to show it Open.
Good work Christopher!
Im curios in one thing.. if you could remove the hood and check if the valve bypass any air at idle or light throttle (just before engagement rpm)?
Does this valve come with different springs like the old one?
Haven't started up the engine yet,. but SURE.Good work Christopher!
So what should I expect to be different when I go for a ride tomorrow Matt?We've used this valve on sleds making over 25psi with the same spring. This valve is by far better and more reliable then the older design.
Just a little less "Chatter" ?Don't expect things to be very different.
The top boost reading really did NOT seem to be greatly impacted by my elevation change. At Wide Open Throttle I was making 9-9.5 all day long.Your afr seems to be in the safe lane! On what elevation did you get 9.5psi?
Ready to try out a good bypass valve now?
BTW, what adjustments did you have to make to your fuel controller to go up 3.5 lbs of boost?
Sent from Moto's iPhad
