Pulled mine apart this weekend, noticed the belt deflection bolt pushes on the washer which causes galling to the housing. This is off 11 Pro 800 with 1800 miles? Also found it has a black spring, according to charts I should be running black/purple for the higher altitude.
What do you think?
VF... doesn't that go under the sencodary spring cup... not against the deflection bolt between the two halves??
I've used the flat roller thrust bearing before and had issues with it failing... now I only use delrin washers
Its a crappy design, they all look like that, atleast everyone that Ive pulled apart.
