Inside lights no worky
slopoke
I have a Pace enclosed (2003 I think) and can't get my inside lights to work. All other electrical works just fine. Any ideas guys? They worked great last time I used it last season.
I have a Continental Cargo and I had the same issue last season. The fuse in my pickup had blown for that circuit when towing another trailer earlier in the year. Make sure you have power coming from the pickup I guess.
Did your other lights (exterior) still work with the blown fuse? Thanks for the reply -- I will go check that right now.
On my trailer the interior lights are tied to the charging circuit on the 7-pin harness... I don't know if that is on a separate fuse from the exterior lights but it is another thing you can check with a test light. Before I put a separate battery into my trailer my interior lights would only work when the key was turned on in the truck....:rolleyes:
Good luck:beer;
All of my other lights worked. The interior would only work when attached to the truck and the truck running (in normal operation). I was baffled so I took the cove molding off and the interior panel expecting a wire to have come off the switch. Felt kind of silly when I finally diagnosed the simple fuse being blown.
What kind of truck?
all newer trucks that have OE 7prong Rv plug-in have fused 12v battery
somr need to have the key on while others dont
I might be able to tell where and what fuse with yr. make & model truck
and yes all other lights will work fine
You guys nailed it! Replaced a fuse in my truck and wa-la, I've got lights again. Wouldn't of thunk it myself! Thanks a bunch. Ever in sw colo, drop me a pm and we'll take a ride.
