O
outlaw11j
I have limited info on this. Do you need to calibrate with the digital gauge or is my reading accurate.
At fire up it zero's itself and goes through the warm up. After that it reads 12.5 at idle. Under power the thing does not come off 10.0 unless full throttle about 12. Plugs do not look that bad but if this reading is right its dead fat.
I guess I should tell you this is on a TRX-1 @ 15psi.
Thanks in advance for any info?????
I have an alpine system with the small tbo. I have the needle droped one clip from stock and the fuel pressure key on 4psi not running.
Sled does appear to pull clean from bottom to top???? No miss.
I do have the led and button but says it is only needed if you do not have the gauge.
