innovate a/f won't work
Y
yamboosta
The gauge on mine shows three horizontal bars(no numbers)
The website says it has no connection. I checked all wires and connnections
and they look good! Could the oxy. sensor be the problem? HELP!!!
Throw it away and get an AEM--one problem to another with mine. BTW, who on here has found the AEM for $250?
check your ground it is the prob usually but those innovates seem to not like snowmobiles lots of guys have had probs with them.
I got mine for 259 + tax with the sensor from mopac The funny thing is one sled shop was $600 for the same one.:rolleyes:
We have one doing the same thing worked great in the morning and after
lunch went back out and - - - wtf checked all wires cant find a problem??
I had the same problem on a cat and had to install a resistor from radio shack.
Innovate motorsports I am pretty sure helped me fix the problem.
Felipe, said to check all the connections as they rattle loose.
I am going to tape them together to hopefully fix the problem.I will update!!
Found the problem, The first step in the instructions say to connect the terminator plug to the IN port of the LC-1 . Well that terminator plug rattled out. Use more tape next time I guess.
Well i thought i had my fixed. After recalibrating and fixing my connection the gauge will only read in the 3.9 thru 5.3 range. Thats not right!!
--- is no communication from the LC1 to the XD16. so its either a power or ground to the LC1, or the 3.5mm stereo plug AKA serial cable has rattled loose, or the termintor has rattled loose.
