Inline filter for turbo oil
Vertical-Extreme
what is everyone using for an inline oil filter for there turbo oil? I finally got my no spill, roll over proof oil res done and would like to filter the oil for a while just in-case there are any particulates in the tank from fabrication. would a simple inline fuel filter work?
I use an inline metal fuel filter from an old Ford truck carb application, it is about 3" long by 1" wide with 1/4 fittings.
Do you use it on the supply side or the pressure side of the pump?
Works for me, filter on the inlet
I ended up grabbing a small clear plastic fuel filter that has metal mesh inside instead of paper. I put mine in between the tank outlet and the pump
Mine is same place as boyko and is a universal filter out of Napa's book. Metal housing, glass see through, and a plastic filter. I think the filter is replaceable as well.
