V
volcano buster
Since I had the motor out anyway, I thought I would tackle this. The lower steering mount on the Lite's have a pressed in zerk. Mine was broken off and short of easy ideas on how to repair it, I came up with this.
Cleaned off area, rough sanded side of 1/4-28 nut and mating surface on steering mount, taper ground the end of the bolt so it would stay over the grease port and clamped together. J-B weld around nut and let dry. Once it is dry I can back the bolt out, paint, then insert grease zerk and grease.
Not a lot of pressure on it, so the J-B weld should hold fine and make a leak-proof seal.
