Impulse nytro intake pipe
B
b_sandgren
How are you guys routing your intake pipe? I can't seem to get mine to fit good and my plastics fit bad around the tank covers now. Mine is currently as far towards the front of the sled as I can get it. The intake boot hits on the charge pipe to intercooler. How are you guys running yours?
It may take some work to get it good, but I got my decent. It still rubs alittle against the charge tube and on the cover. But ok.
Ive heard on this years kits the alu bend may need some cutting.
Thanks. I will go to work on it again. I like where you relocated the radiator catch bottle. Good idea. Mine is stuffed in the nose right now.
Yes I didnt like to have it stuffed in the front either.
Above the secondary is how MPI has it on the sc kits.
Guys that have the impulse intake and the right side aluminum vent :be careful the vent will rub right through the aluminum intake. I cut a chunck of the rubber hose and slid it over the pipe where it touches the screen. No more rubbing.
