B
b_sandgren
I wanted to see what everyone is running for clutching.
Im currently running 15-16 lbs of boost on the closed loop, 2860 turbo system. Using the springs that paul sent me (sorry dont remember colors right now), supertip weights set at 72 grams and shockwave helix set at 1 turn out from the bottom. My secondary spring is set at holes 0 and 1.
Im hitting rev limiter on acceleration, but once it hits rpms will go back down and then it will be fine for the remainder of the acceleration. Should I add more weight or adjust helix. Looks like my next weight would be 74 grams per arm. If I go with weights, spread them evenly across the arm?
Thanks
Thanks
