Ignition power on 2015 KTM 450 XCF
philsummers21
Im trying to be ready for winter before winter hits. I purchased this Painless Cirkit deal so I can wire in power for my GPS, Headlight and handwarmers. My question is where can I tap into ignition on power to activate the relay.
Right under the seat there is a molex that is either 3x3 or 4x4... I'm trying to imagine it now. Nick tapped into power that only works when the bike is running to power my nitrous solenoid. I'll take a picture of it when I get home.
Found it in an old message. It's the Orange wire. Pull the rubber plug out of the bottom and you can plug right into the connector on the underside.
10944912_728038730636591_1413894312_n.jpg 10943230_728038787303252_1805147417_n.jpg
you can just t-tap into the wire, If you want to get fancy with wiring I can point you at pins and seals that you can put into the cap plug on the end of it.
